h792 Posted September 20, 2008 Posted September 20, 2008 Hi, Just realised there are standard names for cad layers rather than my Layer 1 "walls" style of doing things. 1, Is there someone who has painstakingly written these all out so I can just load them in? 2. How do I load them in? 3. If there isn't a source of standard layers in some sort of file, and I write them out this evening (and will share them on the forum), how do I set it up so that those layers allways come up when I start a project? Thanks very much! Howard Quote
nocturne00 Posted September 21, 2008 Posted September 21, 2008 Just make a dwt file and load em up with all your standard layers. eg, A-WALLS, A-WINDOWS etc. that way everytime you start a new file you are already pre loaded with your standard layers Quote
Geoffers Posted September 21, 2008 Posted September 21, 2008 Hi, Just realised there are standard names for cad layers rather than my Layer 1 "walls" style of doing things. 1, Is there someone who has painstakingly written these all out so I can just load them in? 2. How do I load them in? 3. If there isn't a source of standard layers in some sort of file, and I write them out this evening (and will share them on the forum), how do I set it up so that those layers allways come up when I start a project? Thanks very much! Howard in ACAD 'Architecture'the standard layers are preset to BS1192(can't remember at the mo.) or AIA (?). But I think you might have vanilla so don't know if its there - 'layer keys'. See an earlier thread with the title 'layer keys'. still confuses me tho'... Quote
42 Posted September 24, 2008 Posted September 24, 2008 I have attached a script file with the layers that I use. Although my template files have the layers already imbeded, there are time when I need the layers reloading. Simply drag and drop the scr file into the drawing. You could of course set a button to do this, but for once in a blue moon its not worth it. A-layer.scr Quote
SparkyJ Posted June 22, 2012 Posted June 22, 2012 I have attached a script file with the layers that I use. Although my template files have the layers already imbeded, there are time when I need the layers reloading. Simply drag and drop the scr file into the drawing. You could of course set a button to do this, but for once in a blue moon its not worth it. I know this thread is a few years old but was wondering if any other script files are available with the proper AIA or AEC(UK) layering descriptions already written up. I typically get drawings from engineers which use there own in-house standards and would like to just select individual objects and move them to the AIA/AEC layering before I edit the drawings and purge them and send them on to the architects. Quote
