qball Posted November 29, 2010 Posted November 29, 2010 I have this dynamic block, 2 visiblities, stretch and array actions. You can see when you open the file that the arrayed portion of the 2nd visibility shows up. This also happens when inserting the block into a drawing. I tried recreating the block from scratch as well, with the same result. LAGSCREW TEST.DWG Quote
Ryder76 Posted November 29, 2010 Posted November 29, 2010 Can you save your block as a lower version and re-attach? I'm running 2008 and can't open it to take a look at it. Quote
qball Posted November 29, 2010 Author Posted November 29, 2010 2007 version attached LAGSCREW TEST.DWG Quote
Ryder76 Posted November 29, 2010 Posted November 29, 2010 (edited) Ok - here's what I found...on your second visibility the array at distance two for the lagscrew was in the 'visible' state for the 1/2". I selected it and made it invisible and voila no bleed over. Try it and let me know if you get the same result. turn your visibility mode on (bvmode: 1) to see what parameters and actions are associated with which item - I think you will see what I mean. Edited November 29, 2010 by Ryder76 add info Quote
qball Posted November 29, 2010 Author Posted November 29, 2010 it still happens. When I insert the block into a drawing the white threads show up, but when i manipulate any of the dynamic features they go away. Also, the default length for the 1/2" visibility, the threads are not there. Again, change it and they show up. I tried switching my acad profile and resaving the drawing in case it is a profile error. do they insert as shown when you do it? Quote
Ryder76 Posted November 29, 2010 Posted November 29, 2010 sent you a pm with my email. Send me an email message and I'll send you the block I fixed. Quote
