How to update list in dialog boxes?
Hello to all,
I have two list_boxes in one dialog window. How can I put an item from first list to the second in same session of the dialog window.
Thanks!
I'm sure you have this on your lisp file (or similar)
(start_list "1st_Dia");; your key
(mapcar 'add_list ftl_);; your list
Now using "button" function on your DCL file to transfer the a number of items from the first list to the other list
(action_tile .... <your function>  <the button key)
    which includes updating the other list with the same code
(mapcar 'add_list ftl_);; your updated list
something like that... :)
Thank you pBe , now i will try your advice...
Hi pBe i have tryed the code but does not work. My code is
(defun c:task ( )
(vl-load-com)
(setq listTaskstd (list "1" "2" "3" "4" "5"))
(setq dcl (load_dialog "diastd.dcl"))
(if not (new_dialog "Tasks" dcl) (exit))
(start_list "listTaskstd")
(mapcar 'add_list listTaskStd)
(end_list)
(action_tile "addTask" "(setq newTask $value) " )
(action_tile "addButton" "
(start_list listTaskstd)
(mapcar 'add_list newTask )
(end_list)
(start_dialog)
(unload_dialog dcl)
// now is dcl code
Tasks : dialog
label = "My DCL" ;
: boxed_row
: column
: list_box
key = "listTaskstd" ;
width = 60 ;
height = 15 ;
fixed_width = true ;
fixed_height = true ;
multiple_select = false ;
} //row
: boxed_row
: edit_box
key = "addTask" ;
edit_width = 60 ;
: button
label = "Add" ;
key = "addButton" ;
is_default = true ;
alignment = left ;
fixed_width = true;
mnemonic = "Ä";
} // row add task
: button
label = "OK";
key = "accept";
is_default = true;
fixed_width = true;
alignment = centered;
} // task
Hang on.. i'm looking for a link (on this forum) , its the perfect example for what you need :)
Hi Lee,
as always, you are giving the right advice!!!
Thank you. :D
Hi Lee,
Thank you. :D
Ouch :)
anyway, just in case you dont understand it yet.. i tweak your code as your reference
(defun c:task ( )
(vl-load-com)
(if (not listTaskstd_)
 (setq listTaskstd_ (list "1" "2" "3" "4" "5")))
(mapcar 'add_list listTaskStd_)
(end_list)
(action_tile "accept" "(done_dialog 1)")
(action_tile "addTask" "(setq ad_to_list $value)
  (setq listTaskStd_ (acad_strlsort (cons ad_to_list listTaskStd_)))")
(action_tile "addButton" "(start_list \"listTaskstd\")
       (end_list)
        (set_tile \"addTask\" \"\")")
(start_dialog)
(unload_dialog dcl)
Tasks : dialog
label = "My DCL" ;
: boxed_row
: column
: list_box
width = 60 ;
height = 15 ;
} //row
: boxed_row
: edit_box
key = "addTask" ;
edit_width = 60 ;
: button
label = "Add" ;
key = "addButton" ;
is_default = true ;
alignment = left ;
fixed_width = true;
mnemonic = "Ä";
} // row add task
ok_only ;
} // task
and in the futrue. avoid using variable names the same as your key
Edited by pBe
tweaked DCL Added
Thank pBe for your concern !
I will take your advice in future!
If I can help to you with some think, please send an message.
