Ste1978 Posted December 1, 2010 Posted December 1, 2010 I have a part in an assembly I am trying to rotate, so I select 'grip snap' and rotate along a line off the part. The usual 360°. However, for some reason I cannot manually insert an input, say I want 47° I cannot type this in the dialogue box. Is this a bug of some kind? Quote
ecshclark Posted December 2, 2010 Posted December 2, 2010 Within Grip Snap "Rotating about Point" should allow you to input degrees. "Rotate about Point using Reference Geometry" will not. Using a constraint to rotate may be easier. Quote
