matthewrussell Posted September 23, 2008 Author Posted September 23, 2008 Yes that is the location. I just changed the lisp file ill test it out now Quote
matthewrussell Posted September 23, 2008 Author Posted September 23, 2008 Ok I have an idea. It seems to me that it is looking for a file called PersonalCADSupportSec-ball.dwg instead of just looking for Sec-ball.dwg as shown below in the command box. Ok this is what I am thinking since the file location is set can this part of the code look like this (command "layer" "m" "TAGS" "" "insert" (strcat "Sec-ball") #loc DMS DMS "0" #sectno #drawno "insert" (strcat "Sec-arr") #loc (* -1 DMS) DMS (rtd #ang) ); Arrow All I did was remove $PATH from both inserts. Because what it looks like to me is that it is for a file that does not exist. But in the mean time I will make the cad files have PersonalCADSupport before them and see if it works Command: insert-sectmark-block Enter SCALE: 15 Select Center point of Section Bubble: Rotation of Section mark?: Section Number <1>: 1 Drawing Reference <2>: 2 "PersonalCADSupportSec-ball.dwg": Can't find file in search path: C:\Documents and Settings\matthew.russell\My Documents\ (current directory) D:\Personal\CAD\Support\ D:\Personal\CAD\MENU\ D:\Personal\CAD\MENU\ICONS\ C:\sp2000\ X:\Acad\Support\Brisbane\Linetypes\ X:\Acad\Support\Brisbane\Fonts\ C:\Documents and Settings\matthew.russell\Application Data\Autodesk\AutoCAD 2009\R17.2\enu\support\ C:\Program Files\AutoCAD 2009\support\ C:\Program Files\AutoCAD 2009\fonts\ C:\Program Files\AutoCAD 2009\help\ C:\Program Files\AutoCAD 2009\express\ C:\Program Files\AutoCAD 2009\drv\ C:\Program Files\AutoCAD 2009\ Quote
matthewrussell Posted September 23, 2008 Author Posted September 23, 2008 ok well my idea didnt work so im out of them now. Quote
russell84 Posted September 23, 2008 Posted September 23, 2008 Matthew I didnt know you changed the code. it works here and i'm using 2009. leave the code as (command "layer" "m" "TAGS" "" "insert" (strcat $PATH "Sec-ball") #loc DMS DMS "0" #sectno #drawno "insert" (strcat $PATH "Sec-arr") #loc (* -1 DMS) DMS (rtd #ang) ); Arrow also did you copy the blocks that i had originally posted?? You are confusing me with what you have done. Just simply leave the code alone - change the one line defining the $PATH to the location that your blocks are then run the lisp. It will work. you can change whatever you want from there. So go back - copy the code i posted. change the $PATH to the location of your blocks (remember change "\" to "/" then try it. If that doesnt work i'll help you out. Quote
matthewrussell Posted September 23, 2008 Author Posted September 23, 2008 Got it working. Thank you heaps. I can edit the block with no problems correct. like set linetypes Thank you heaps Quote
