CiCAD Posted December 2, 2010 Posted December 2, 2010 Can anyone tell me if its possible to set up text options so when labeling with leaders the first letter of every word is capitalised? This way meaning i dont have to press shift so often. Quote
SuperCAD Posted December 2, 2010 Posted December 2, 2010 Why not just leave it all CAPS? Capitalizing the first letter of each word would be rather annoying to read, and improper. Quote
fuccaro Posted December 2, 2010 Posted December 2, 2010 After the text is entered... don't you have the option Title Case in your right-click menu? I can't check it right now, sorry. Quote
irneb Posted December 2, 2010 Posted December 2, 2010 After the text is entered... don't you have the option Title Case in your right-click menu? I can't check it right now, sorry.In AC2008 there's only UPPERCASE (Ctrl+Shift+U) and lowercase (Ctrl+Shift+L) after you've selected the text (Ctrl+A) in the MText editor. BTW, in the Right-Click menu there's an option to turn on AutoCAPS ... this will have all the text you type in capitals irrespective of your CapsLock. I think you're referring to TCase express tool. That can modify existing DText/MText to have "Sentence case."; lowercase; UPPERCASE; Title Case; tOGGLE cASE. But unfortunately it screws up Annotative text, as it uses a method which doesn't work properly when a text is annotative. Quote
