Bogbadbob658 Posted December 2, 2010 Posted December 2, 2010 Hi, Does anybody a lisp routine that can generate a random polyline from a previously drawn object. I need something that works similarly to Napkin or Revcloud but something I can control a bit better. I’m, trying to draw a hedge line in plan but all the linestyles I have found are too regimented. Quote
ReMark Posted December 2, 2010 Posted December 2, 2010 You can try using the Sketch command but you end up with individual line segments which you will then have to Pedit to join into a continuous polyline. Quote
nestly Posted December 2, 2010 Posted December 2, 2010 SKETCH also has a polyline option SKETCH > Type > Polyline Quote
rkent Posted December 2, 2010 Posted December 2, 2010 There is even a Spline option in 2011, not sure if it was there in 2010 or not. SKPOLY is the variable to set to line (0), pline (1), spline (2) outside of the command options. Quote
