so to freeze the layers that are now created, I just added the following code within the vlax-for l function
(vl-catch-all-apply 'vla-put-Freeze (list l :vlax-true))
  • Replies 30
  • Lee Mac
    16
  • ccowgill
    13
  • alanjt
    2
Popular Days
That may work - I've never tested to see if a layer status is retained following the CopyObjects operation.
it appears to, as I have tested it and it does freeze the newly created layers. On the [cr] and snvalid, I checked and it is not allowing a space at the beginning of a string, so I'll just resolve it by adding the space to the strcat:
Command: (snvalid " test")
nil
Command: (snvalid "to test")
T
Yes, I meant with the snvalid removed as well - see the code in the original post.
Ok, I got it. thanks again for all your help.
What about something like this?
(defun c:CopyToLayerWithSuffix (/ suffix ss)
 ;; Alan J. Thompson, 12.02.10
 (vl-load-com)
 (setq suffix (getstring T "\nSpecify layer suffix: "))
 (if (setq ss (ssget "_:L"))
   ((lambda (layers match / name layer new item)
      (vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*))
        (or (wcmatch (strcase (setq layer (vla-get-layer x))) match)
            (vla-put-layer
              (vla-copy x)
              (cond
                ((cdr (assoc 2 (tblsearch "LAYER" (setq name (strcat layer suffix))))))
                ((setq new  (vla-add layers name)
                       item (vla-item layers layer)
                 (foreach p '(Color Description Linetype Lineweight Material PlotStyleName TrueColor)
                   (vl-catch-all-apply
                     (function vlax-put-property)
                     (list new p (vlax-get-property item p))
                 name
      (vla-delete ss)
     (vla-get-layers
       (cond (*AcadDoc*)
             ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
     (strcat "*" suffix)
Nice one Alan - that was the way I was initially suggesting - I just didn't want the legwork of copying all the layer properties :P
Thanks. I was thinking the same thing about ODBX.
well that would put it back in line, coding style-wise, with the layer/layerstate program you helped me out with a few months ago at AUGI. Although looking at Lee's coding, it looks very similar to what was done in the original LAFreeze program I was trying to modify. Perhaps Lee wrote it originally?
I'm afraid I've written too much code to remember :ouch: I'd have to see the code...
