My plot style table search path has the right directory but when i want to print something i can't see my .ctb plot styles?? please help!
How did you lose them? They just don't disappear all by themselves. Is this a new installation of AutoCAD 11?
Yes it is... But the folder has tons of plot styles, but still only a few shows in print dialog??
Your files may not at correct folder. You can do a simple step, go to your folders have plot styles, copy the plot styles what you need. After that go back to your AutoCad File-> Plot Style Manager-> paste the plot style to there. Close your Autocad program and open again. See how it work.
Could you please explain it a bit more detailed?? Thanks in advance!
Are you seeing any plot styles? for example .stb plot styles.
If you are seeing only .stb plot styles, then perhaps you need CONVERTPSTYLES.
I'm seeing .stb plot styles. I'll try your suggestion.
