I have downloaded a trial of autocad Lt, as I an trying to convince my boss to go autocad instead of a pretty bad lanscape design program we are using.
it downloaded but won,t allow me to use the trial ("run" greyed out) but wants me to activate it. Any help would be apreciated as I dont have much time to make my case. It is a brand new computer so wont have any hidden registry files.:oops:
Cheers all
I assume this is the 2011 trial from the Autodesk website?
Are you absolutely positive that the trial version has not already been loaded on this machine?
hey cad 64, the computer was only started 5 hours earlier. Yes the vresion is 2011 I am thinking perhaps i have inadvertantly tried to install it twice allthoug I don'remember doing so. I am thinking it is a restore to factory settings (not an option)
Any thoughts
Cheers
You can only install the trial version once. If you try to install it a second time it will not work.
Do you have another computer you can install it on?
