how to find a block handle in a drawing
Looking for a lisp to find a handle
Mike
Here is direct way from the command line .....
(sssetfirst nil (ssget "_x" '((0 . "INSERT")(2 . "YourBlockName"))))
No sorry that is not what i`m searching for. I`m using Autoad electrical and do a export to Excel. Some of the blocks missing attribute data. Autocad generates handles of all the used blocks. So i need a lisp where i can give in a handle and Autocad zooms into to that block.
Mike
look into ( handent ) -David
i`m not so into lisp and so i do not know how to make a lisp with this
I suppose the simplest would be something like:
(defun c:zoomhandle ( / e )
 (if (setq e (handent (getstring "\nSpecify Handle: ")))
   (command "_.zoom" "_O" e "")
In the mean time, use AfraLISP to learn LISP.
works great,.................thanks
It was intended to be a starting point for your program - demonstrating how to use 'handent'.
*shrug*
