Guys
Im a newbie in autolisp can someone help me to edit this code. I want to change the output from polyline to spline and labeled as per 50 meters.
(defun timeini ()
 (setq s (getvar "DATE"))
 (setq seconds (* 86400.0 (- s (fix s))))
(defun timeend ()
 (setq s1 (getvar "DATE"))
 (setq seconds1 (* 86400.0 (- s1 (fix s1))))
 (setq seconds2 (fix (- seconds1 seconds)))
 (princ
   (strcat "\nTime : "
       (itoa seconds2)
       " seconds"
(defun inivar ()
 (setq    cmd_ini    (getvar "cmdecho")
   fla_ini    (getvar "flatland")
   osm_ini    (getvar "osmode")
   ort_ini    (getvar "orthomode")
   plt_ini    (getvar "plinetype")
   aup_ini    (getvar "auprec")
   uni_ini    (getvar "unitmode")
   lun_ini    (getvar "lunits")
   diz_ini    (getvar "dimzin")
   edg_ini    (getvar "edgemode")
 (setvar "CMDECHO" 0)
 (setvar "FLATLAND" 0)
 (setvar "OSMODE" 0)
 (setvar "ORTHOMODE" 0)
 (setvar "PLINETYPE" 2)
 (setvar "AUPREC" 0)
 (setvar "UNITMODE" 1)
 (setvar "LUNITS" 2)
 (setvar "DIMZIN" 0)
 (setvar "EDGEMODE" 1)
(defun recvar ()
 (setvar "CMDECHO" cmd_ini)
 (setvar "FLATLAND" fla_ini)
 (setvar "OSMODE" osm_ini)
 (setvar "ORTHOMODE" ort_ini)
 (setvar "PLINETYPE" plt_ini)
 (setvar "AUPREC" aup_ini)
 (setvar "UNITMODE" uni_ini)
 (setvar "LUNITS" lun_ini)
 (setvar "DIMZIN" diz_ini)
 (setvar "EDGEMODE" edg_ini)
(defun getlayname ()
 (setq contourstest nil)
 (setq    layername
    (getstring
      "\nPlease enter the layer name of the contours: "
 (setq    contourstest
    (ssget    "_x"
       (list (cons -4 "<OR")
             (cons -4 "<AND")
             (cons 0 "lwpolyline")
             (cons 8 layername)
             (cons -4 "AND>")
             (cons -4 "<AND")
             (cons 0 "polyline")
             (cons 8 layername)
             (cons -4 "AND>")
             (cons -4 "<AND")
             (cons 0 "line")
             (cons 8 layername)
             (cons -4 "AND>")
             (cons -4 "<AND")
             (cons 0 "spline")
             (cons 8 layername)
             (cons -4 "AND>")
             (cons -4 "OR>")
 (while (= contourstest nil)
   (princ "\nNo contours selected...")
   (setq layername
      (getstring
   (setq contourstest
      (ssget "_x"
           (cons -4 "<AND")
           (cons 8 layername)
           (cons -4 "AND>")
           (cons -4 "<AND")
           (cons 0 "polyline")
           (cons 8 layername)
           (cons -4 "AND>")
           (cons -4 "<AND")
           (cons 0 "line")
           (cons 8 layername)
           (cons -4 "AND>")
           (cons -4 "<AND")
           (cons 0 "spline")
           (cons 8 layername)
           (cons -4 "AND>")
           (cons -4 "OR>")
(defun activexsupport ()
 (vl-load-com)
 (setq    *modelspace*
    (vla-get-modelspace
      (vla-get-activedocument (vlax-get-acad-object))
(defun esttexto    ()
 (vl-cmdf "._style" "PMSF-TEXT" "romans" 2.50 0.80 0 "n" "n" "n")
(defun getha ()
 ;; this entity must be a lwpolyline
 (activexsupport)
 (setq
   ha (entsel "\nSelect the Horizontal alignment: ")
 (while (= ha nil)
     (princ "\nNothing selected...")
     (setq ha
 (setq ha-type (cdr (assoc 0 (entget (car ha)))))
 (if (not (equal ha-type "LWPOLYLINE"))
     (setq ha nil)
     (princ "\n***Horizontal Alignment must be a LWPolyline***")
 (while (= ha nil)
     (setq ha
     (setq ha nil)
 (setq ha-ename (entget (car ha)))
 (setq ha-ename (cdr (assoc -1 ha-ename)))
 (setq ha-object (vlax-ename->vla-object ha-ename))
 (vl-cmdf "._text"
      (vlax-curve-getstartpoint ha-object)
      "0"
      "A"
 (vl-cmdf "._text"
      (vlax-curve-getendpoint ha-object)
      "0"
      "B"
(defun getexaggeration ()
 (initget 2)
 (setq ve (getreal "\nEnter the vertical exaggeration <1>: "))
 (if (= ve nil)
   (setq ve 1)
(defun listptintersect ()
 (setq listaxy nil)
 (setq hazvalue (caddr (vlax-curve-getStartPoint ha-object)))
 (setq curvas contourstest)
 (setq ncurvas (sslength curvas))
 (setq listaxy nil)
 (setq counter 0)
 (while (< counter ncurvas)
     (setq cnivel-ename (ssname curvas counter))
     (setq cnivel-object (vlax-ename->vla-object cnivel-ename))
     (setq cnivelzvalue
        (caddr (vlax-curve-getStartPoint cnivel-object))
     (setq ha-ENTITY
        (subst (cons 38 cnivelzvalue)
           (assoc 38 (entget (car ha)))
           (entget (car ha))
     (entmod ha-ENTITY)
     (setq intersectpt
        (vlax-variant-value
          (vlax-invoke-method
        ha-object
        "IntersectWith"
        cnivel-object
        acExtendNone
     (setq test nil)
     (setq
   test (vl-catch-all-apply
          'vlax-safearray->list
          (list intersectpt)
     (setq error (vl-catch-all-error-p test))
     (if (/= error t)
     (setq intersectpt (vlax-safearray->list intersectpt))
     (setq interlength (length intersectpt))
     (if (> interlength 3)
         (setq dividelength (/ interlength 3))
         (setq count 0)
         (while (< count interlength)
         (setq    newpt (list (nth count intersectpt)
                   (nth (+ count 1) intersectpt)
                   (nth (+ count 2) intersectpt)
         (setq x (vlax-curve-getdistatPoint ha-ename newpt))
         (setq z (caddr intersectpt))
         (setq xy (list x (* z ve)))
         (setq
           listaxy (append listaxy (list xy))
         (setq count (+ count 3))
         (setq x (vlax-curve-getdistatPoint ha-ename intersectpt))
         (setq
     (setq    ha-ENTITY
        (subst    (cons 38 hazvalue)
           (entget (car ha))
     (entmod ha-ENTITY)
     (setq counter (1+ counter))
 (setq    listaxy
    (vl-sort listaxy
         (function (lambda (e1 e2)
                 (< (car e1) (car e2))
 (setq    startdist (vlax-curve-getdistatPoint
           ha-ename
           (vlax-curve-getstartpoint ha-ename)
   enddist      (vlax-curve-getdistatPoint
           ha-ename
           (vlax-curve-getendpoint ha-ename)
 (setq    pt1 (car (car listaxy))
   pt2 (car (last listaxy))
 (if (/= startdist pt1)
     (setq x startdist)
     (setq y (+ (* (/ (- (cadr (car listaxy)) (cadr (cadr listaxy)))
              (- (car (cadr listaxy)) (car (car listaxy)))
           (- (car (car listaxy)) startdist)
     (setq xy (list x y))
     (setq
     (setq listaxy
        (vl-sort listaxy
 (if (/= enddist pt1)
     (setq pos (1- (length listaxy)))
     (setq x enddist)
     (setq y
        (/ (- (cadr (nth pos listaxy))
              (cadr (nth (1- pos) listaxy))
           (- (car (nth pos listaxy)) (car (nth (1- pos) listaxy)))
        (- enddist (car (nth pos listaxy)))
     (setq
     (setq listaxy
        (vl-sort listaxy
(defun createprofile ()
 (setq variante-listaxy (apply 'append listaxy))
 (setq    arraySpace
    (vlax-make-safearray
      vlax-vbdouble
      (cons 0
        (- (length variante-listaxy) 1)
    (vlax-safearray-fill arraySpace variante-listaxy)
 (vlax-make-variant variante-listaxy)
 (setq spline (vla-addLightweightPolyline
       *ModelSpace*
       variante-listaxy
 (vl-cmdf "._text"
      (vlax-curve-getstartpoint spline)
      "0"
      "A"
 (vl-cmdf "._text"
      (vlax-curve-getendpoint spline)
      "0"
      "B"
(defun annotate    ()
 (setq    xini (car (vlax-curve-getstartpoint pline))
   xend (car (vlax-curve-getendpoint pline))
   y    (*    (fix
         (/ (cadr (car    (vl-sort listaxy
                            (< (cadr e1) (cadr e2))
            ve
       ve
 ;;end setq
 (if (< y 0)
   (setq y (- y (* 1 ve)))
 (setq var-xyini (apply 'append (list (list xini y 0))))
 (setq var-xyend (apply 'append (list (list xend y 0))))
 (createline)
 (setq yref (strcat "REFERENCE: " (rtos (/ y ve) 2 2)))
 (setq ptloc (list (- xini 30.0) y))
 (vl-cmdf "._text" ptloc "0" yref)
 (setq lengthlistaxy (length listaxy))
 (setq count 0)
 (while (< count lengthlistaxy)
                (list (list (car (nth count listaxy))
                    (cadr (nth count listaxy))
                    0
     (setq
            (list (list (car (nth count listaxy)) y 0))
     (createline)
     (setq ytext (rtos (/ (cadr (nth count listaxy)) ve) 2 2))
     (setq xpt (car (nth count listaxy)))
     (setq xtext (rtos xpt 2 2));;CB 11/24/09
     (setq ptloc (list xpt (- y 10.0)))
     (setq ptloc2 (list xpt (- y 30.0)));;CB 11/24/09
     (vl-cmdf "._text" ptloc "90" ytext)
     (vl-cmdf "._text" ptloc2 "90" xtext);;CB 11/24/09
     (setq count (1+ count))
(defun createline ()
 (setq    arraySpace
      vlax-vbdouble
      (cons 0
        (- (length var-xyini) 1)
 (setq    var-xyini
    (vlax-safearray-fill arraySpace var-xyini)
 (vlax-make-variant var-xyini)
 (setq    arraySpace
      vlax-vbdouble
      (cons 0
        (- (length var-xyend) 1)
 (setq    var-xyend
    (vlax-safearray-fill arraySpace var-xyend)
 (vlax-make-variant var-xyend)
 (setq    line (vla-addline
          *ModelSpace*
          var-xyini
          var-xyend
;;print chainage and elevs to drawing CAB 11/20/09
(defun print_table ()
 (initget 1)
 (setq TabInsPt (getpoint "\nPick upper left table location: "))
 (setq Tab_lbl1 "%HAINAGE")
 (command "._text" TabInsPt 0.0 Tab_lbl1)
 (setq TxtLen (caadr (textbox (entget (entlast)))))
 (setq Pt2 (list (+ (car TabInsPt) txtlen (cdr (assoc 40 (entget (entlast))))) (cadr TabInsPt)))
 (foreach ch_val listaxy
    (setq sta (rtos (car ch_val) 2 2))
    (command "._text" "" sta)
 (command "._text" Pt2 0.0 "%LEVATION")
    (setq elev (rtos (cadr ch_val) 2 2))
    (command "._text" "" elev)
(defun c:qp ()
 (timeini)
 (inivar)
 (getlayname)
 (esttexto)
 (getha)
 (getexaggeration)
 (listptintersect)
 (createprofile)
 (annotate)
 ;;;(print_table);;11/20/09
 (vl-cmdf "._zoom"
 (recvar)
 (timeend)
Edited by Tiger
added codetags
