gargoyle27 Posted December 7, 2010 Posted December 7, 2010 i have an assembly i want to scale down (about 1/4) is that possible? it's simply because we know we will screw up somewhere along the way when machining it, so we'll work out the bugs on a smaller, cheaper piece of steel thanks Quote
MarkFlayler Posted December 7, 2010 Posted December 7, 2010 Open a new File Use the Derive Command on the Model Tab Derive the assembly into a single part with maintain each solid as a solid body Set a Scale factor on the Options Tab Use Make Components to create a new scaled down assembly automatically and save the new ipts accordingly Quote
gargoyle27 Posted December 7, 2010 Author Posted December 7, 2010 i'm using 2009 so i think my options are a little different, i got the "derived assembly" window, it has a "scale factor" box i set as 0.25, do you know what else i need to change in this window? Quote
MarkFlayler Posted December 7, 2010 Posted December 7, 2010 Opps should have seen you are on 2009. Stop right there you cannot do it the easy way. You will have to do this for EVERY part manually if you want separate IPTs from it. Inventor 2010 and 2011 are 4 steps compared to the 4 step times the number of parts you have in there. Quote
gargoyle27 Posted December 7, 2010 Author Posted December 7, 2010 nope, don't need separate ipts, i made them separately, but the part itself is a single piece Quote
JD Mather Posted December 7, 2010 Posted December 7, 2010 You just need to select the iam file in the Derived Component dialog box to derive it into a single part. Quote
gargoyle27 Posted December 8, 2010 Author Posted December 8, 2010 yeah, i got it firgure out, thanks Quote
mikeconde Posted November 23, 2012 Posted November 23, 2012 Prof. Mather's, can this scaling be easily done in inventor 2010 as well? tia Quote
JD Mather Posted November 23, 2012 Posted November 23, 2012 Prof. Mather's, can this scaling be easily done in inventor 2010 as well? tia Go back and re-read the entire thread - your question has already been answered. Pay particular attention to Post #4. Quote
