is it possible to diasable dwl file creation
i have recently started using a nas hard drive, yesterday i had some dwl files left on the drive after cad closed, is there a way to stop cad creating these files, i am the only one using the nas so no one else will be opening the cad files at the same time.
I was under the impression if AutoCAD closed in a normally manner dwl files would automatically be deleted.
If Autocad crashes, sometimes the dwl file doesn't get deleted. But 99.9% of the time they do get deleted when the program closes normally.
I haven't seen an orphaned lock file since release 13. Saw enough of them then to last a lifetime, but that's a whole other story.
I have read of two methods to stop their creation. One seems rather simple while the other requires hacking the Registry (make a backup first). Try number 1 first.
1. Move WhoHas.arx to another folder not in AutoCAD's search path.
2. Edit the Registry by deleting the key HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R21\ACAD-xxxx:yyy\Applications\AcadWhoHas.
