clicker Posted December 8, 2010 Posted December 8, 2010 It annoys me how the default for the rotation tool is counter clockwise. Does anyone else agree? Anyone know why autocad software engineers chose to make it this way? Quote
ReMark Posted December 8, 2010 Posted December 8, 2010 Which rotation tool are we talking about? Quote
clicker Posted December 8, 2010 Author Posted December 8, 2010 the rotate command, aka RO I just always wondered why negative values produce clockwise rotations and positive values produce counter clockwise values... seems counter-intuitive to me. Quote
clicker Posted December 8, 2010 Author Posted December 8, 2010 ya , I know it's a lame thread but I'm trying to get my posts up to 10 so I can have a custom avatar :/ Quote
ReMark Posted December 8, 2010 Posted December 8, 2010 Set it and forget it in your template and you won't have to complain again. See the Units command. Quote
Patrick Hughes Posted December 9, 2010 Posted December 9, 2010 I just always wondered why negative values produce clockwise rotations and positive values produce counter clockwise values... seems counter-intuitive to me. It does seem counter-intuitive. Rotation is based on something called the right hand rule. If you google that and look at the image results you'll see how it applies. Essentially if you look at the direction your right hand fingers curl, that is positive direction. The right hand rule is also applied to the UCS. Using the right hand rule you can also easily determine if a thread is right or left hand. Place a screw down with the shank laying in a horizontal fashion. Now place you right hand over the threads - if the angle of the thread is generally the angle of you thumb it is a right hand thread. Left hand will match you left hand thumb direction. Quote
clicker Posted December 9, 2010 Author Posted December 9, 2010 It does seem counter-intuitive. Rotation is based on something called the right hand rule. If you google that and look at the image results you'll see how it applies. Essentially if you look at the direction your right hand fingers curl, that is positive direction. The right hand rule is also applied to the UCS. Using the right hand rule you can also easily determine if a thread is right or left hand. Place a screw down with the shank laying in a horizontal fashion. Now place you right hand over the threads - if the angle of the thread is generally the angle of you thumb it is a right hand thread. Left hand will match you left hand thumb direction. I get it, that's interesting! thanks Patrick. Quote
ReMark Posted December 9, 2010 Posted December 9, 2010 In his book Surveying Practice by Philip Kissam the author states the transitman should read his angles in a clockwise direction. After the initial reading of 0d00'00" all angles are turned to the right, thus putting 0deg at 12 o'clock, 90deg at 3 o'clock, 180deg at 6 o'clock and 270deg at 9 o'clock. Trivia: In aviation the nose of one's aircraft is said to be at 12 o'clock. The tail of the aircraft at 6 o'clock. Quote
Patrick Hughes Posted December 9, 2010 Posted December 9, 2010 You're welcome. (It looks like I've got a problem typing you when I mean "your") Quote
designerstuart Posted December 9, 2010 Posted December 9, 2010 DUDE! thanks!at least you got your avatar now ;-) Quote
hazardman Posted December 9, 2010 Posted December 9, 2010 isn't the angle like some sort of cartesian rule...you start at positive x-axis and angle up towards the positve y-axis (y being +90 degrees from x)?.. Quote
clicker Posted December 9, 2010 Author Posted December 9, 2010 never thought of that... but I still like clockwise being positive! Quote
clicker Posted December 9, 2010 Author Posted December 9, 2010 In his book Surveying Practice by Philip Kissam the author states the transitman should read his angles in a clockwise direction. After the initial reading of 0d00'00" all angles are turned to the right, thus putting 0deg at 12 o'clock, 90deg at 3 o'clock, 180deg at 6 o'clock and 270deg at 9 o'clock. Trivia: In aviation the nose of one's aircraft is said to be at 12 o'clock. The tail of the aircraft at 6 o'clock. boo-yah! this is the way it should be Quote
ReMark Posted December 9, 2010 Posted December 9, 2010 got my avatar ... yippee! And here I thought they upped your requirement to 12 posts. Haven't I seen you hanging around the lab? You look very familiar. Quote
clicker Posted December 9, 2010 Author Posted December 9, 2010 And here I thought they upped your requirement to 12 posts. Haven't I seen you hanging around the lab? You look very familiar. haha , I'm in the CAD lab pretty much every day. Living off the crumbs of upper management. Quote
