Hi,
I need to move a DCL box out of the middle of the screen, is there a way to do that?
Thanks for your help.
Shawndoe
Hi,
That did it thanks alot.
Have a good one.
Shawndoe
  • 1 month later...
I have looked at this thread, and the file from kruuger, however I am still lost on dcl box placement. Is there a way to direct the where the dialog box is placed on the screen when it opens ? Anyone willing to share....
You can specify an initial position in screen coordinates, then the position of the dialog will be returned bythe done_dialog function, which you can store for the next time.
I'll post an example if you wish :)
Ok, so I couldn't resist making an example :D
(defun c:test ( / *error* dcl dch )
 ;; Example by Lee Mac 2011  -  www.lee-mac.com
 ;; Demonstrates how to remember a dialog screen
 ;; position for next use.
 ;; Requires accompanying file: test.dcl to be
 ;; in AutoCAD Support Path.
 (defun *error* ( msg )
   (if dch (unload_dialog dch))
       (princ (strcat "\n** Error: " msg " **")))
 (cond
     (not
       (and
         (setq dcl (findfile "test.dcl"))
         (< 0 (setq dch (load_dialog dcl)))
     (princ "\n** DCL File not found **")
     (not (new_dialog "test" dch "" (cond ( *screenpoint* ) ( '(-1 -1) ))))
     (setq dch (unload_dialog dch))
     (princ "\n** Dialog could not be Loaded **")
   (t
     (action_tile "accept" "(setq *screenpoint* (done_dialog 1))")
     (start_dialog)
Save the following as 'test.dcl' in a Support Path:
test : dialog { label = "Test Dialog";
 spacer;
 : text { label = "Move me"; alignment = centered; }
 spacer;
 : button { key = "accept"; is_default = true; label = "I'm Done"; }
Position is stored as a global variable in this case, but the code could be altered to convert the screen position into a string and store it in the registry between drawing sessions.
Enjoy!
Lee
  • 4 years later...
Snownut,
You would need to set *dlgpos* as a list of 2 integers, defining position of upper left corner of your DCL.
So you would need to (getvar 'screensize) and know the pixel size of your dcl.
(setq *dlgpos* '(0 0)) would place it at upper left corner of Autocad Screen,
overlapping the ribbon. For that case no need to know thw size of the box.
ymg
