Squirrel Cottage Posted December 10, 2010 Posted December 10, 2010 Hi Team Is there a way of converting a converting or saving a AutoCAD 2010 drawing into a EPS file / vector file ? Many thanks Alan Quote
f700es Posted December 10, 2010 Posted December 10, 2010 If I am not wrong, I think you can set up a post-script printer to plot to an .eps file much like a .pdf file. Let me double check when I get CAD open. Yep, works. OK, go to install a new Plotter/Printer For Manufacturers select Adobe and for Model select PostScript Level 2 Next, Next, Plot to File, Give it a name and then Finish Give it a try Quote
Squirrel Cottage Posted December 10, 2010 Author Posted December 10, 2010 Hi Thank you. No sooner had I post the thread a tutorial sprang up in similar threads echoing your advice. I followed the instructions and all up and running. Have a very merry Christmas Kind regards Alan Quote
f700es Posted December 10, 2010 Posted December 10, 2010 Glad you figured it out Alan You have a merry Christmas yourself and a Happy New Year! Quote
