chelsea1307 Posted September 22, 2008 Posted September 22, 2008 Is there a way to change all the page setups of pages in a sheet set manager? Im trying to print all sheets in a sheet set but they are set to 30x42's and i only need 11x17's. any suggestions? Quote
Dipali Posted September 22, 2008 Posted September 22, 2008 creat that new pagesetup in one of the files & save it with name. than go to publish> select all sheets you need to print> than you will see page set up column, click on the down arrow(drop button) & select import> browse to the drawing you have pageset up saved as & select so it will override the current pagesetup. sorry i can't be more specific becaus using LT at the moment so can't check it out exactly Quote
lisplost Posted September 22, 2008 Posted September 22, 2008 If you don't want to change every one because this might be a one time deal, you can change the page setup in the plot options for just one drawing. Go through your plot choices, picking paper size, printer and so on. Save these changes under a name such as 11x17 and then do the publish. When you publish you will be able to select all the drawings you want to print. Do a select all and right click select change page setup- a drop down will appear. This will show you the page set up you created earlier. select that and publish. All drawings will come out 11x17. Hope this helps. Quote
rustysilo Posted September 22, 2008 Posted September 22, 2008 Create an 11x17 page setup in your Page Setup Overrides file > Select your sheet set (or the sheets you want to print) > Right-click > Publish > Publish using Page Setup Override > Select the page setup you desire. Quote
