WIPEOUT Area Outside Polyline
Hello CAD Wizards,
When I implement the WIPEOUT command the area inside the polyline gets "wiped out". how can I make it so that the area outside the polyline gets "wiped out" instead?
Thanks,
JustAnIntern
That is not how WIPEOUTs work. Depending on your situation, you may be able to use multiple wipeouts to hide the areas around what you are trying to show, you may be able to use a viewport to do it, or you can create a block out of your geometry (or xref it into a new drawing), then use XCLIP to do what you want.
unfortunately wiipeout does not work like that, however, XCLIP has an invert clip option. Your objects will have to be blocked though
how would i use tframes. when i type TFRAMES is only gives me the option to either
toggle the boundary on or off. i'm trying to do it in paperspace
Well then if you are doing this in PS then i would recommend you utilize viewports as rkmcswain suggested
it would have to be an irregular shaped viewport, something that autocad really hates
Its ok, you are the boss of autocad, you tell HIM what to do!! :lol: I wouldnt worry about it if i were you.. Use the Object option of MVIEW, and if your autocad has a problem with it, tell him to come talk to me!
thanks. there is a way to clip everything inside the viewport, outside a boundary drawn on PS. i heard it was done through tframes. i know there's different ways to do one specific task in CAD but i'm trying to find out one specific way to do it.
Actually, XCLIP and WIPEOUT already do the inverse of each other.
XCLIP hides geometry outside the border, while WIPEOUT hides geometry inside the border.
Using the Inverse option of XCLIP makes it act more like a wipeout.
...i heard it was done through tframes.
Tframes is nothing more than a shortcut to turn the frame (or visible border) OFF or ON for all IMAGEs and WIPEOUTs.
Is that a question or a statement?
