Hello All,
how can i use tframes to clip everything inside the viewport, outside a boundary drawn on PS?
Thank You
Edited by justAnIntern
Can you be more specific? From your description, you want to clip an area between an inner boundary and a viewport. The obvious solution to that is to reduce the viewport edges to the boundary. I'd guess that's not what you're asking.
thanks for the reply. its hard to describe some problems i encounter in autoCAD but i got it figured out : )
Care to share, maybe with screenshots?
last time i tried to upload a screenshot i couldn't because i didn't have enough privileges. i just did a wipeout outside the area of interest. i tried to select a polyline boundary but i couldn't. autocad lets you trace an irregular polygon, i didn't know that until just now. thanks CyberAngel and rkmcswain.
