Can you Inquiry Angles in DMS?
Is there away to change the output of an Angle Inquiry in DMS (deg., min, sec) instead of Decimal Degrees? I've tried changing the "Units" and changeing my dimstyle, meither of which work. Any sugestuions?
Thanks,
John
ACAD Civil 3d 2011
What happens if you set the system variable AUNITS to 1, and AUPREC to 4 ?
Have you edited.....
Prospector > Settings Tab > Right Click on Drawing Name > Edit Drawing Settings > Ambient Settings > Direction > Format
