System Variable SDI
Hi all,
I just ran across an unusual situation on one of my users systems.
I built an image for all users to have when it is deployed.
i never touched the system variables. However, in the last hour i have had two users say that there is a publishing issue.
[ATTACH]25241[/ATTACH]
I went and fixed it back so that the value is zero and that corrected the issue.
My question would be: What could start changing the system variables without going directly in and changing the value?
Normally I would respond that perhaps it was a rogue lisp routine but in this case I'm not so sure.
  • 2 weeks later...
hi,
i've found many third party packages change that variable including civil3d.
instead of pushing that variable to the users, i suggest letting the users have their choice (what it's designed for) and adding a quick mod to the publish command.
what i do is make a shortcut "pub" that mods the "sdi" variable, then activates "publish", then restore "sdi" to users preference.
(defun C:PUB ()
(setq STORE_SDI (getvar "sdi"))
(setvar "sdi" 0)
(command "publish")
(setvar "sdi" STORE_SDI)
(command "regen")
(print)
);end-of-defun
i add this to the startup that everyone sees when they activate acad.
karl
