Hi!
I have a question about labeling a corridor. I have a corridor which I want to label in plane view with it´s z-values every 10 meter. Does anyone here knows the trick how to do that?
I don´t want to manually check every 10m for the height and write it in mtext..
I have attached an example of what I want to achieve..
Hi!
Have you tried the copy comand? U still have to change the numbers if they are changed.
Hello!
Yes but I want the labels to automatically change height value if the corridors profile is changed.
The alternatives that I already have is to use height labeling of a surface, but that means i must click on every place where I want my height-labels. But they do place the right z-value autmatic and they are dynamic. But they dont appear automatically along the alignemant at a user specific frequency.
The other alternative is to use cogo points along the alignement, and set it to show each points z-value. This method works pefect, except for one thing and that is that I cant change frequency-range for the cogo-points.. they automatically appear each 1,5 meter. Does anyone know how to change this frequency?
