Run a command for all the tabs in a drawing?
I want to simply run a command (or a series of commands) on every tab
in a drawing. The tabs most likely are not named in any consistent fashion.
It might be as simple as going to a tab and zooming extents.
I have no idea how to cycle through the tabs and end
when the command is run on the last tab.
Help please!!
Thanks!
You could use a construct such as:
(foreach tab (layoutlist)
 (setvar 'CTAB tab)
Bear in mind that (layoutlist) excludes the Model tab, to include it, you could use:
(foreach tab (cons "Model" (layoutlist))
 (setvar 'CTAB tab)
Lee
Thanks Lee...
I'm digging through older threads right now looking at what others have done.
In my frustration I always forget to search before posting...
'preciate it!
sample
(defun c:test ( / ot ac )
 (vl-load-com)
 (setq this_dwg (vlax-get-acad-object))
  (foreach d (layoutlist)
     (setvar 'CTAB d)
   (vla-ZoomExtents this_dwg))
Nevermind: :lol:
Lee you're a smoking gun :)
If you find my Finalblitz lisp, you could try that. It works on multiple tabs and multiple drawings.
