ademontis Posted December 16, 2010 Posted December 16, 2010 Hi everybody, I am a CAD drafter with a need of having a LSP that breaks a polyline when inserting a Block. The goal is, having a polyline (e.g.: a pipe routing) and adding the block, that it cuts the polyline in the intersection point and deletes the part of line covered by the block. I have tried the AutoBlockBreak LSP by Lee Mac and it is very useful except the case I need to get blocks from a Tool Palette instead of browsing from a folder. Is there a way to easily modify the LSP? Please notice that I have no LSP programming experience. Otherwise, I had an old AutoCAD lsp that used to do the work but it doesn't do anymore on AutoCAD 2008... but I can't figure out how to modify it. I attach it here for quick reference (PIINSYM command). Thanks in advance, Cheers. Alessandro Demontis Rome P&ID.txt Quote
lpseifert Posted December 16, 2010 Posted December 16, 2010 Have a look here http://www.cadtutor.net/forum/showthread.php?53423-self-trimming-block&highlight=wipeout Quote
ademontis Posted December 16, 2010 Author Posted December 16, 2010 Have a look herehttp://www.cadtutor.net/forum/showthread.php?53423-self-trimming-block&highlight=wipeout Thank you lp but the wipeout procedure is not suitable for my problem for two main reasons: - I am not allowed to redifine the blocks (that already exist) in order to add the wipeout polygon - i need the line to be trimmed non only for a graphical result but because of a next step where lines are used to represent attributes or moved. Imagine a plant pipe... i add the valve, or a pump, or an instrument as a block on the pipe and the polyline needs to be truncaed because after adding the block i have to be able to select the two pieces of line and move them on different layers or give them different global width values. Moreover i need to be able to use the blocks from a previously created toolpalette. This is an image of what I mean: the line above is the 'start situation' and the other one is the goal i would need to achieve. Quote
