RJW Posted September 22, 2008 Posted September 22, 2008 I created the routine below as part of a larger routine for converting drawings to my company's standard layers. It works perfectly except I need the user to either select a line or hit 'enter' before continuing. As it is now, if you pick an empty point in space instead of a line,the routine just keeps running. As an example, if the Matchprop does exactly what I want...it keeps prompting you to pick a source point before it goes any further. TIA for any help! (if (setq ent1 (entsel "\n Pick an existing ELECTRICAL FIXTURE.................'Enter' if none ")) (setq lay1 (value 8 (entget (car ent1)))) ) (if lay1 (if (setq ss (ssget "x" (list (cons 410 (getvar "ctab")) (cons 8 lay1)))) (progn (sssetfirst nil ss)) ) ) (command "chprop" "P" "" "la" "D-EX-ELECT" "C" "bylayer" "LT" "bylayer" "") Quote
ASMI Posted September 23, 2008 Posted September 23, 2008 I think you need to create list of all your company layers do loop with FOREACH function. ; create all company layers list (setq layLst '("D-EX-ELECT" "Electrical2" "Electrical3" "Electrical4")) ; foreach layer in list (foreach lay layLst ; if user has select entity for this layer and selection set has created (if (and (setq cEnt(entsel(strcat "\nSelect entity for '" lay "' or Enter for none> "))) (setq cLay(cdr(assoc 8(entget(car cEnt))))) (setq cSet(ssget "x"(list(cons 410(getvar "ctab"))(cons 8 cLay)))) ); and and (progn ; higlight selection set for user can to see it (sssetfirst nil cSet) (initget "Yes No") ; if user press Y or hit Enter (setq cAns(getkword (strcat "\nDo you want to cnahge layer to '" lay "'? [Yes/No]<Yes>: "))) (if(/= "No" cAns) ; change properties of selection set (command "chprop" "P" "" "la" lay "C" "bylayer" "LT" "bylayer" "") (princ(strcat "\nLayer '" lay "' passed by user ")) ); end if ); end progn (princ(strcat "\nNothing selected for '" lay)) ); end if ); end foreach Not tested. Quote
RJW Posted September 23, 2008 Author Posted September 23, 2008 Kewl..thanks....I'll give it a try! Quote
RJW Posted September 23, 2008 Author Posted September 23, 2008 ASMI, It works perfectly, but the one missing element is if you accidently select nothing, it skips ahead to the next layer. How do I get it make sure an entity is selected before moving on to the next step? Thanks again! Quote
Lee Mac Posted September 23, 2008 Posted September 23, 2008 ASMI, Is this possible? ; create all company layers list (setq layLst '("D-EX-ELECT" "Electrical2" "Electrical3" "Electrical4")) ; foreach layer in list (foreach lay layLst ; if user has select entity for this layer and selection set has created (if (and (setq cEnt(entsel(strcat "\nSelect entity for '" lay "' or Enter for none> "))) (setq cLay(cdr(assoc 8(entget(car cEnt))))) (setq cSet(ssget "x"(list(cons 410(getvar "ctab"))(cons 8 cLay)))) ); and and (progn ; higlight selection set for user can to see it (sssetfirst nil cSet) (initget "Yes No") ; if user press Y or hit Enter (setq cAns(getkword (strcat "\nDo you want to cnahge layer to '" lay "'? [Yes/No]<Yes>: "))) (if(/= "No" cAns) ; change properties of selection set (command "chprop" "P" "" "la" lay "C" "bylayer" "LT" "bylayer" "") (princ(strcat "\nLayer '" lay "' passed by user ")) ); end if ); end progn (while (and (= (setq cEnt(entsel(strcat "\nSelect entity for '" lay "' or Enter for none> "))) nil) (setq cLay(cdr(assoc 8(entget(car cEnt))))) (setq cSet(ssget "x"(list(cons 410(getvar "ctab"))(cons 8 cLay)))) ); end and ; higlight selection set for user can to see it (sssetfirst nil cSet) (initget "Yes No") ; if user press Y or hit Enter (setq cAns(getkword (strcat "\nDo you want to cnahge layer to '" lay "'? [Yes/No]<Yes>: "))) (if(/= "No" cAns) ; change properties of selection set (command "chprop" "P" "" "la" lay "C" "bylayer" "LT" "bylayer" "") ); end if ); end while ); end if ); end foreach Quote
ASMI Posted September 23, 2008 Posted September 23, 2008 Is this? (defun c:test(/ layLst cEnt cLay cSet cAns) ; create all company layers list (setq layLst '("D-EX-ELECT" "Electrical2" "Electrical3" "Electrical4")) ; foreach layer in list (foreach lay layLst (setq cEnt nil) ; if user has select entity for this layer and selection set has created (while(not cEnt) (setq cEnt(entsel(strcat "\nSelect entity for '" lay "' > "))) (if (and cEnt (setq cLay(cdr(assoc 8(entget(car cEnt))))) (setq cSet(ssget "x"(list(cons 410(getvar "ctab"))(cons 8 cLay)))) ); and and (progn ; higlight selection set for user can to see it (sssetfirst nil cSet) (initget "Yes No") ; if user press Y or hit Enter (setq cAns(getkword (strcat "\nDo you want to cnahge layer to '" lay "'? [Yes/No] <Yes>: "))) (if(/= "No" cAns) ; change properties of selection set (command "chprop" "P" "" "la" lay "C" "bylayer" "LT" "bylayer" "") (progn (princ(strcat "\nLayer '" lay "' passed by user ")) (sssetfirst nil nil) ); end progn ); end if ); end progn (progn (princ(strcat "\n>>> Nothing selected for '" lay "' <<< ")) (initget "Next Repeat") (if(= "Next"(setq cAns(getkword "\nRepeat or [Next]? <Repeat>: "))) (progn (setq cEnt T) (princ(strcat "\nLayer '" lay "' passed by user ")) ); end progn ); end if ); end progn ); end if ); end while ); end foreach (princ "\n<<< End of layer list. Exit. >>> ") (princ) ); end of c:test Quote
CAB Posted September 23, 2008 Posted September 23, 2008 Another variation. (defun c:test (/ layLst cEnt cLay cSet cAns) ;; create all company layers list (setq layLst '("D-EX-ELECT" "Electrical2" "Electrical3" "Electrical4")) ;; foreach layer in list (foreach lay layLst ;; if user has select entity for this layer and selection set has created (while (cond ((and (setq cEnt (entsel (strcat "\nSelect entity for '" lay "' > "))) (setq cLay (cdr (assoc 8 (entget (car cEnt))))) ) (setq cSet (ssget "x" (list (cons 410 (getvar "ctab")) (cons 8 cLay)))) ;; higlight selection set for user can to see it (sssetfirst nil cSet) (initget "Yes No") ;; if user press Y or hit Enter (setq cAns (getkword (strcat "\nDo you want to change layer to '" lay "'? [Yes/No] <Yes>: "))) (if (/= "No" cAns) ; change properties of selection set (command "chprop" "P" "" "la" lay "C" "bylayer" "LT" "bylayer" "") (progn (princ (strcat "\nLayer '" lay "' passed by user ")) (sssetfirst nil nil) ) ) ) ((progn (princ (strcat "\n>>> Nothing selected for '" lay "' <<< ")) (initget "Next Repeat") (if (= "Next" (setq cAns (getkword "\nRepeat or [Next]? <Repeat>: "))) (prompt (strcat "\nLayer '" lay "' passed by user ")) t ) ; end if ) ) ) ) ; end while ) ; end foreach (princ "\n<<< End of layer list. Exit. >>> ") (princ) ) ; end of c:test Quote
