Heyy everyone;
I have a 3D model (I did it from the plan), and i used the SECTIONPLANE command to get the sections from it.
I can't seem to be able to generate the elevations, though. I was told it is possible.
Anyone has any idea?
Thanks
There is an Orthographic option to the SectionPlane command. Once selected the user can specify top, front, side, etc.
Yes, i have tried it this way, the problem is that my structure is not aligned with the axis and the elevations are taken from an angle i do not care for.
Also, i have tried the flatshot option but i got so lost with the ucs and whatknot.
Thanks anyway :)
Wouldn't it make sense to reorient the UCS temporarily to eliminate the angle?
With Flatshot you set the view of the object you want then execute the command. If the object looks a bit distorted switch to a top view in the UCS you are using.
