are you trying to make a solid or a surface? if you draw the 2d profile of your cornice you can join it by using the Pedit command. then use the extrude command. since you are using acad00 you do not have a loft or sweep command.
The EXTRUDE command gives one the option of extruding along a path too. That might come in handy for extruding the cornice around the perimeter of a room.
