i open autocad 2002 and a runtime error pops up. i click ok and autocad 2002 disappears.
Is this the error message you are seeing?
Microsoft Visual C++ Runtime Library
C:\Program files\Autocad 2002\acad.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information
Is there a specific runtime error number listed?
What OS are you using?
Have all service packs been installed for your version of AutoCAD 2002?
Edited by ReMark
dear ReMARK,
YES SIR THE ERROR KEEP POPPING OUT WHEN I OPEN AUTO CAD 2002 IS "MICROSOFT VISUAL C++ RUNTIME ERROR"
C:\PROGRAM FILES\AUTOCAD 2002\ACAD .EXE
THIS APPLICATION HASW REQUESTED THE RUNTIME TO TERMINATE IT IN AN UNUSAL WAY.
PLEASE CONTACT THE APPLICATION SUPPORT TEAM FOR MORE INFORMATION.
THER IS NO NUMBER ERROR INCLUDED.
I"M USING WINDOWS 7 ULTIMATE. PLEASE HELP THANK YUO.
yes sir the error is, "MICROSOFT VISUAL C++ RUNTIME LIBRARY.
ERROR
C:\PROGRAM FILES\AUTOCAD 2002\ACAD. exe
this application has requested the runtime to terminate it in an unusual way. please contact the applications support team for more information.
there is no error number listed, and i am using windows 7 ultimate.
This is important. Did you load any service packs for AutoCAD 2002?
OK...Win7 Ultimate (good choice). Is it the 32-bit or 64-bit version?
When did the problem first occur?
no, idid not load any service packs for autocad 2002 however loaded add on survey tools.
the 32 bit version.
it occurred days after i installed it. it operates for few days then after that the error pops out.
Stop what you are doing and go to the AutoDesk website. Find and download any service packs and hotfixes that were released for AutoCAD 2002.
Create a Restore Point.
Using Add/Remove feature in Windows remove the add-on survey tools.
Create a second Restore Point.
Install all service packs and hotfixes.
Run AutoCAD a full day. Does the runtime problem reoccur?
If not, create a third Restore Point then install the add-on survey tools.
What happens now?
By the way, you do know that running AutoCAD 2002 on a Win7 system is likely to be problematic right? AutoDesk does not recommend/support the installation of AC 2002 on a computer running Win7.
