G'day all
I have a question regarding the edit field command using mtext.
Currently in my titleblock I have a Filename Field that generates the file name of my .dwg. AutoCAD allows you to format the file name using uppercase, lowercase, first capital and title case. I would like my file name to be completly in capitals except for the .dwg part.
Does anyone know how to modify the field expression to do this?
The field expression is: %%
Right now the file name reads as: U:\ws10-11\Designs\C - Traffic Management\Wanda Road\TM191901.dwg
I would like the file name to read as: U:\WS10-11\DESIGNS\C - TRAFFIC MANAGEMENT\WANDA ROAD\TM191901.dwg
Any help would be greatly appreciated :)
hi matt,
i would suggest using caps & not checking the extension box for the field, and then adding (regular) text at the end ".dwg"
karl
