Croftyno1 Posted December 24, 2010 Posted December 24, 2010 I am currently using ssget to select layers i want to include in my lisp program but as you can see below i have to drag a window on the drawing 4 times to save each layer to a set. I was wondering if there is a way to select one window around the objects (instead of repeating it four times) and it filters out the layers i want and saves them to four different SETQ. Below is what i wrote in the program currently (prompt "\nSelect the Lines to be Added together:") (setq ss1 (ssget (list (cons 8 "layer1")))) (setq ss2 (ssget (list (cons 8 "layer2")))) (setq ss3 (ssget (list (cons 8 "layer3")))) (setq ss4 (ssget (list (cons 8 "layer4")))) As you can see i have to ssget four times, just wondered if i can use it once and is stores in SS1, SS2, SS3, SS4 Thanks Andrew Quote
Tharwat Posted December 24, 2010 Posted December 24, 2010 You can use the "_x" after each ssget to get them automatically . Example . (setq ss1 (ssget[color=red][b] "_x"[/b][/color] (list (cons 8 "layer1")))) Implement the above example to all your codes. Tharwat Quote
pBe Posted December 24, 2010 Posted December 24, 2010 Try this: (defun c:test () (setq ss_set '("ss1" "ss2" "ss3")cnt -1) (foreach layername (list "Layer1" "Layer2" "Layer3") (set (setq tempo (read (nth (setq cnt (1+ cnt)) ss_set))) (ssget "_x" (list (cons 8 layername)))) ) ) Of course you need to update the Layer list and Variable name to your needs Merry Xmas To ALLL!!! Quote
David Bethel Posted December 24, 2010 Posted December 24, 2010 Or maybe: [b][color=BLACK]([/color][/b]setq i 1[b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]repeat 4 [b][color=FUCHSIA]([/color][/b]set [b][color=NAVY]([/color][/b]read [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]"SS"[/color] [b][color=GREEN]([/color][/b]itoa i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]cons 8 [b][color=BLUE]([/color][/b]strcat [color=#2f4f4f]"LAYER"[/color] [b][color=RED]([/color][/b]itoa i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq i [b][color=NAVY]([/color][/b]1+ i[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
pBe Posted December 24, 2010 Posted December 24, 2010 Or maybe: [b][color=BLACK]([/color][/b]setq i 1[b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]repeat 4 [b][color=FUCHSIA]([/color][/b]set [b][color=NAVY]([/color][/b]read [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]"SS"[/color] [b][color=GREEN]([/color][/b]itoa i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]cons 8 [b][color=BLUE]([/color][/b]strcat [color=#2f4f4f]"LAYER"[/color] [b][color=RED]([/color][/b]itoa i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq i [b][color=NAVY]([/color][/b]1+ i[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Yup. I agree. that will eliminate the need for the list. but then again. if you have different layers with different name.. you may still need to make a list for layers Good point David Quote
David Bethel Posted December 24, 2010 Posted December 24, 2010 I use something similar to this a lot for detailing assemblies: [color=#8b4513];;;GET LAYER NUMBERS[/color] [b][color=BLACK]([/color][/b]while [b][color=FUCHSIA]([/color][/b]progn [b][color=NAVY]([/color][/b]and il [b][color=MAROON]([/color][/b]princ [color=#2f4f4f]"\n"[/color][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]prin1 il[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq in [b][color=MAROON]([/color][/b]getint [color=#2f4f4f]"\nLayer Number To Select: "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]and in [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]member in il[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq il [b][color=MAROON]([/color][/b]cons in il[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] [color=#8b4513];;;GET PICK SETS[/color] [b][color=BLACK]([/color][/b]foreach i il [b][color=FUCHSIA]([/color][/b]setq dxs [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]"SS"[/color] [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]< i 10[b][color=GREEN])[/color][/b] [color=#2f4f4f]"0"[/color] [color=#2f4f4f]""[/color][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]itoa i[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]set [b][color=NAVY]([/color][/b]read dxs[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]cons 8 [b][color=BLUE]([/color][/b]strcat [color=#2f4f4f]"LAYER"[/color] [b][color=RED]([/color][/b]itoa i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
alanjt Posted December 24, 2010 Posted December 24, 2010 (ssget '((8 . "pizza,beer,cheese,fun"))) Quote
Lee Mac Posted December 24, 2010 Posted December 24, 2010 I think the OP requested that a window be selected hence I would opt for Alan's demonstration. I wouldn't approach it in the way my code illustrates, however it does show a way to assign the variables as the OP originally requests: (defun c:test ( / ss ) (vl-load-com) (if (setq ss (ssget (setq l '((8 . "Layer1,Layer2,Layer3,Layer4"))))) ( (lambda ( l / i e sym ) (repeat (setq i (sslength ss)) (ssadd (setq e (ssname ss (setq i (1- i)))) (cond ( (eval (setq sym (read (strcat "ss" ( (lambda ( j ) (vl-some (function (lambda ( x ) (setq j (1+ j)) (if (wcmatch (strcase (cdr (assoc 8 (entget e)))) (strcase x)) (itoa j) ) ) ) l ) ) 0 ) ) ) ) ) ) ( (set sym (ssadd)) ) ) ) ) ) (LM:str->lst (cdar l) ",") ) ) ) ;;-------------------=={ String to List }==-------------------;; ;; ;; ;; Separates a string into a list of strings using a ;; ;; specified delimiter string ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2010 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; str - string to process ;; ;; del - delimiter by which to separate the string ;; ;;------------------------------------------------------------;; ;; Returns: A list of strings ;; ;;------------------------------------------------------------;; (defun LM:str->lst ( str del / pos ) (vl-load-com) ;; © Lee Mac 2010 (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) Coded more for academia than anything else - it reminds me of setting variables for every list item... Quote
David Bethel Posted December 24, 2010 Posted December 24, 2010 Lee, Sometimes I think you must have won a lottery of parenthesis, your prize was an unlimited number one can use in their lifetime. Nest 'til you drop kinda thing! It's fun to watch, a ***** to decode. -David Quote
Lee Mac Posted December 24, 2010 Posted December 24, 2010 Sometimes I think you must have won a lottery of parenthesis, your prize was an unlimited number one can use in their lifetime. Nest 'til you drop kinda thing! It's fun to watch, a ***** to decode. -David Spices things up a bit Quote
