Jamesbowyer Posted September 23, 2008 Posted September 23, 2008 Is it possible to render the image from a camera? And if not, what is the point of them?! I can get the camera window up, but then no idea how to render from it. If I simply press render, it renders what is currently in the viewport, and the advanced render settings have nothing about rendering camera views. Help!! Quote
shift1313 Posted September 23, 2008 Posted September 23, 2008 When you render i believe there are two different render buttons, render and render region. try the region. i have never tried it. on older versions you would have a drop down box in the render window but im not sure on 08-09 Quote
Noahma Posted September 23, 2008 Posted September 23, 2008 when I have a camera up, I right click on it, and then set to current and render from there Quote
Jamesbowyer Posted September 24, 2008 Author Posted September 24, 2008 when I have a camera up, I right click on it, and then set to current and render from there Is that right click on the camera itself or the camera window? I tried right clicking on the camera window, and got nothing, but haven't tried the camera itself. Quote
Cad64 Posted September 24, 2008 Posted September 24, 2008 Is it possible to render the image from a camera? And if not, what is the point of them?! Yes, that's the whole point of the camera. Go to Cadclips.com and watch the video tutorial about Cameras. Quote
CaddJax Posted July 18, 2014 Posted July 18, 2014 Is it possible to render the image from a camera? Yep. Set your cameras up as you want them. In the cmd line: View select the camera of choice as 'Current' - OK Your screen will be set to the current camera's view, Render away. Quote
CaddJax Posted July 18, 2014 Posted July 18, 2014 Annnnnddddd.... now I see that I've dug up a thread that's 5 years old. You're welcome. [oops] Quote
