demeon Posted December 28, 2010 Posted December 28, 2010 im working on building, using 0.5, 0.35 and 0.25 lineweights. when i print it on A3, 0.5 is 1mm, 0.35 is 0.7 mm and so.. i thought 0.5 means 0.5mm, im beginner, am i wrong?? is there any possibility to set scale for lineweights without changing it manually? i am so desperade, dont have time to change it all again pls help Quote
ReMark Posted December 28, 2010 Posted December 28, 2010 Lineweights can be imperial or metric. I doubt that you would inadvertently mix the two up. Quote
demeon Posted December 28, 2010 Author Posted December 28, 2010 i dont think i mixed it up, im using autocad in metric units, what should i do now? is there anything to print my 0.5 line in autocad as 0.5mm on paper? Quote
ReMark Posted December 28, 2010 Posted December 28, 2010 Lineweights can be assigned in a couple of different ways. One option is via your ctb or stb plot style file. The other way is via the lineweight property in the Layer Properties Manager. A third option is provided in some plotter software but I don't know many people who use it. Quote
