Hi, every one what is shortest way of purge. for example i open one dwg and without open second dwg i purge all dwgs.:wink:
I thought the purge button was pretty quick as it was. Maybe a LISP routine to purge all open drawings?
To clean up multiple drawings the best approach would be to use a script file in batch mode. You should probably consider incorporating the Audit command in your script file as well to audit and fix corrupted elements.
Visit the AutoDesk website and download ScriptPro. It is a free utility program that can be used in batch mode on any number of AutoCAD drawing files.
