elevation values
Hey everybody,
I´ve seen this before and don´t remember what comand is used to facilitate setting elevation values after defining 0,0 co-ordinate?
Can anybody help?<a href=http://img229.imageshack.us/img229/8922/sc1ar9.th.png' alt='sc1ar9.th.png'>thpix.gif[/img]
sorry image too small...<a href=http://img299.imageshack.us/img299/8206/sc1vq7.th.png' alt='sc1vq7.th.png'>thpix.gif[/img]
the elevation is in Autocad as your Z when you are in UCS world, so normaly you create objects at 0 elevation (z) so if you wanted it on another elevation (100 for example) simply move it there
(assuming you only wish to move the object in a Z direction)
Move > *select object* > D (displacement) > 0,0,100 > enter
This will move your object 100 units up vertically (use -100 if you wanted to move it down vertically)
wise,
i got that part, i don´t know how to dimension the elevations....
It's hard to see from your photo but if all you want to do is dim the Elevation in the X & Y plain then you can just click on the line and hit properties to see the value (make sure the line in straight) and then type mtext to put that on the drawing.
If it's a large drawing a lisp were by you just click and the value appears might help.
thanks, that might do it.
sorry michaeloureiro the photo you included wasn't showing up yesterday!
When i find the command, i´ll post it.
..for the elevation dimensioning that is.
  • 11 months later...
Think i found it....ordinate dimensions, which lets you dimension relative to one point. OD makes it easy to dimension elevations and sections relative to the site.
