pBe Posted December 29, 2010 Share Posted December 29, 2010 Did you try it? see how it shows the entities within a group name? only thing is it wont show you groups outside of model space... anyway. back to the drawing board... Quote Link to comment Share on other sites More sharing options...
Sweety Posted December 29, 2010 Author Share Posted December 29, 2010 I think it may explode groups , but in order of the selection set and without being known which one of group would be exploded and which one I would like to keep . Am I right ? Quote Link to comment Share on other sites More sharing options...
pBe Posted December 29, 2010 Share Posted December 29, 2010 well.. the code suppose to show you the group name and hihglighted in screen Command: test Command: Group name *A1 Specify action [eXplode/Continue]: X Group name DDD[color=blue]<----- this is the group name[/color] Specify action [eXplode/Continue]: C [color=#0000ff]<----- this is the continue option[/color] Group Name DDD not exploded[color=blue]<------message group DDD not exploded[/color] Group name GROUP7X Specify action [eXplode/Continue]: c Group Name GROUP7X not exploded Group name THIS_GROUP1 Specify action [eXplode/Continue]: x [color=#0000ff]<----- this is the explode option : Group1 is exploded[/color] Group name THISGROUP2 Specify action [eXplode/Continue]: c Group Name THISGROUP2 not exploded its fun writing this one... crude... but fun Quote Link to comment Share on other sites More sharing options...
David Bethel Posted December 29, 2010 Share Posted December 29, 2010 I have no idea as to who was the author of this tidbit: (defun c:KillGroups ( / count gent gdict) (setq count 0 gent(cdadr(member'(3 . "ACAD_GROUP") (entget(namedobjdict)))) gdict (entget gent) ) (foreach i gdict (if (= (car i) 3) ;;entdel is not required in R14, & should be removed (progn (entdel(dictremove gent (cdr i))) (setq count (1+ count))) ) ) (princ (strcat "\nPurged " (itoa count) " groups.")) (princ) );c:killgroups -David Quote Link to comment Share on other sites More sharing options...
