arsalan_gz Posted January 1, 2011 Posted January 1, 2011 hi I'm having difficulty to change the scale in my drawing screen . I mean when I run the program the numbers written on my coordinate bar are so huge something like milimeters , so that with a gentle move on the screen I'm having great amount of difference can anyone help me to modify to centimeters? Quote
eldon Posted January 2, 2011 Posted January 2, 2011 when I run the program the numbers written on my coordinate bar are so huge something like milimeters It may be that you are drawing a long way from 0,0. Try moving everything closer to that point. AutoCAD does not know what units you are drawing in. If there are too many figures after the decimal point, set the precision with less places. The drawing screen is scaled by zooming. Quote
shafiqsaidee Posted January 2, 2011 Posted January 2, 2011 If your project area is big and you used milimeters for units so its usual because when you move crosshair it shows the location of the coordinates in left hand site of your drawing area. it might not be change in centimeter, if you scale your project in centimeter so in this time its possible or if you want to see closer points you can use zoom in command. Quote
