Is Reg.Exp possible for Autocad Mac version?
or anybody know the Mac equivalent for Reg.Exp?
EDIT: Btw I'm mot Mac user... just curious thats all :roll:
  • Replies 25
  • Michaels
    10
  • pBe
    9
  • irneb
    4
  • lpseifert
    1
Not sure, but I wouldn't think so. It's loaded from Windows' DLLs for VBScript. How to accomplish that on OSX is beyond me. Maybe someone else has / can give it a try. Or maybe there's some other library to load on Mac (unfortunately though it will have to be loaded through ActiveX, which I think is already a problem on Mac).
Note: if there are two (2) "-" on your text it will only replace the first one found
depending on your needs, we can revise it to loop back.. :)
Also we can add user input for string to find and string to substitute if needed
Yes pBe.
I noticed that I may have two commas in my text , so how to locate the position of both of them please ?
Example .
1234,abcd,567
So the first comma is already known but how to get the location of the second one ?
Many thanks
Michaels
See post #10 (by David )
See post #11 (the updated code )
See post #13 (by Lee Mac (Reg.Exp method) and
and #20 (the methods as explained by irneb)
OK, going with pure AutoLisp, assume str contains the string "1234,abcd,567", and ch contains the char to search (i.e. ","):
(setq pos 0 ch1 nil ch2 nil)
(while (and (not ch2) (<= (setq pos (1+ pos)) (strlen str)))
 (if (eq ch (substr str pos 1))
   (if ch1 (setq ch2 pos) (setq ch1 pos))
After this ch1 would contain the value 5 and ch2 the value 10. These are the 1-based indexes of the 1st & 2nd commas found in the string.
Doing the same with VL extensions:
(setq ch1 (vl-string-search ch str))
(setq ch2 (vl-string-search ch str (1+ ch1)))
The 2nd line only searches from the position after the 1st found (1+ ch). Note however ch1=4 and ch2=9 now, i.e. the 0-based indexes. So if you now want to extract using substr you'll need to add 1 to each.
The RegEx method to just find the positions of all searching characters:
(setq found (RX:Search str ch)) ; Returns ((4 . ",") (9 . ","))
(setq ch1 (car (nth 0 found))
     ch2 (car (nth 1 found))
Again it would be 0-based.
After using either of the 3 methods, you need to extract only the portions before and after and combine with the new replacement. Let's say the replacement is saved in variable new.
(setq str (strcat (substr str 1 ch1) new (substr str ch2))) ;When using 1-based
(setq str (strcat (substr str 1 (1+ ch1)) new (substr str (1+ ch2)))) ;When using 0-based
But then why not simply use RegEx to replace the string for you?
(setq str (RX:Replace str (strcat ch "[^" ch "]*" ch) (strcat ch new ch)))
That one line does everything of all of the above, and it does it a lot faster, with none of the ancillary variables like pos, ch1, ch2 & found as needed by the other methods.
