Change the object layer of block to on which the block is inserted
Hai all,
I have a drawing that has many blocks, the problem is that the layer of objects contained inside the blocks are different from the layer on which the block is inserted. is there any lisp that can change the object layer to the block insertion layer.
attach is the drawing for reference.
Thanks in advance.
block-layers.dwg
Sounds like you would rather want to change all objects within the block to layer "0" so that they may inherit whatever layer the block is placed.
Consider this function perhaps:
[color=#990099];;---------------=={ Apply to Block Objects }==---------------;;[/color]
[color=#990099];;                                                            ;;[/color]
[color=#990099];;  Applies a supplied function to all objects in a block     ;;[/color]
[color=#990099];;  definition.                                               ;;[/color]
[color=#990099];;------------------------------------------------------------;;[/color]
[color=#990099];;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;[/color]
[color=#990099];;  Arguments:                                                ;;[/color]
[color=#990099];;  _blockname - name of block to apply function              ;;[/color]
[color=#990099];;  _function  - function to apply to all objects in block    ;;[/color]
[color=#990099];;  Returns:  T if block is found, else nil                   ;;[/color]
[color=RED]([/color][color=BLUE]defun[/color] [color=black]LM:ApplytoBlockObjects[/color] [color=RED]([/color] _blockname _function [color=RED])[/color]
 [color=RED]([/color][color=BLUE]vl-load-com[/color][color=RED])[/color]
 [color=#990099];; © Lee Mac 2010[/color]
   [color=RED]([/color][color=BLUE]lambda[/color] [color=RED]([/color] _function [color=BLUE]/[/color] def [color=RED])[/color]
     [color=RED]([/color][color=BLUE]if[/color]
       [color=RED]([/color][color=BLUE]not[/color]
         [color=RED]([/color][color=BLUE]vl-catch-all-error-p[/color]
           [color=RED]([/color][color=BLUE]setq[/color] def
             [color=RED]([/color][color=BLUE]vl-catch-all-apply[/color] [color=DARKRED]'[/color][color=BLUE]vla-item[/color]
               [color=RED]([/color][color=BLUE]list[/color]
                 [color=RED]([/color][color=BLUE]vla-get-blocks[/color]
                   [color=RED]([/color][color=BLUE]vla-get-ActiveDocument[/color] [color=RED]([/color][color=BLUE]vlax-get-acad-object[/color][color=RED]))[/color]
                 _blockname
       [color=RED]([/color][color=BLUE]vlax-for[/color] obj def [color=RED]([/color]_function obj[color=RED]))[/color]
   [color=RED]([/color][color=BLUE]eval[/color] _function[color=RED])[/color]
[color=#990099];; Test Function to Move all Objects in a Block to Layer "0"[/color]
[color=RED]([/color][color=BLUE]defun[/color] [color=black]c:test[/color] [color=RED]([/color] [color=BLUE]/[/color] ss l [color=RED])[/color]
 [color=RED]([/color][color=BLUE]if[/color] [color=RED]([/color][color=BLUE]setq[/color] ss [color=RED]([/color][color=BLUE]ssget[/color] [color=#a52a2a]"_+.:E:S"[/color] [color=DARKRED]'[/color][color=RED](([/color][color=#009900]0[/color] [color=DARKRED].[/color] [color=#a52a2a]"INSERT"[/color][color=RED]))))[/color]
   [color=RED]([/color][color=BLUE]progn[/color]
     [color=RED]([/color][color=black]LM:ApplytoBlockObjects[/color] [color=RED]([/color][color=BLUE]cdr[/color] [color=RED]([/color][color=BLUE]assoc[/color] [color=#009900]2[/color] [color=RED]([/color][color=BLUE]setq[/color] l [color=RED]([/color][color=BLUE]entget[/color] [color=RED]([/color][color=BLUE]ssname[/color] ss [color=#009900]0[/color][color=RED])))))[/color]
       [color=RED]([/color][color=BLUE]function[/color]
         [color=RED]([/color][color=BLUE]lambda[/color] [color=RED]([/color] obj [color=RED])[/color] [color=RED]([/color][color=BLUE]vla-put-Layer[/color] obj [color=#a52a2a]"0"[/color][color=RED]))[/color]
     [color=RED]([/color][color=BLUE]if[/color] [color=RED]([/color][color=BLUE]=[/color] [color=#009900]1[/color] [color=RED]([/color][color=BLUE]cdr[/color] [color=RED]([/color][color=BLUE]assoc[/color] [color=#009900]66[/color] l[color=RED])))[/color]
       [color=RED]([/color][color=BLUE]vl-cmdf[/color] [color=#a52a2a]"_.attsync"[/color] [color=#a52a2a]"_N"[/color] [color=RED]([/color][color=BLUE]cdr[/color] [color=RED]([/color][color=BLUE]assoc[/color] [color=#009900]2[/color] l[color=RED])))[/color]
 [color=RED]([/color][color=BLUE]princ[/color][color=RED])[/color]
