ILoveMadoka Posted January 4, 2011 Posted January 4, 2011 How do I run a script without having everything returned to the command line? Something similar to an @Echo Off in DOS?? Possible? Thanks!! Quote
JPlanera Posted January 4, 2011 Posted January 4, 2011 try (setvar "CMDECHO" 0) then set it to 1 when the script is done Quote
BlackBox Posted February 15, 2011 Posted February 15, 2011 This will not eliminate the command line prompts for all AutoCAD commands... I often need to modify the NOMUTT sysvar as well. Quote
