is it possible to just do a flatshot of specific 3d objects or areas? Rather than all the objects on the drawing.
No it isn't but you can use the SectionPlane command to create a 2D block of a 3D object.
Sorry about my first answer. I was thinking of something I just worked on. Unfortunately I forgot there was only one 3D object in the entire drawing.
Edited by ReMark
Yes, it does work. You select the area and it creates a flatshot of selected items. Very nice!
SOLPROF would be the command to use for a single object. Or isolate the single object to it's own layer and use FLATSHOT (can be a pain in the butt depending on your drawing complexity).
solprof says it needs a layout. But 43st just reminded me that in A2011 you can isolate objects, then flatshot from modelspace and it works. You don't need to change to its own layer.
I never thought that it would acknowledge an isolated object.. that's pretty awesome.
Maybe someday AutoCad will allow you to properly use visual styles to do layouts with linetypes.
