How do I clear the command log?
Video:
Please let me know.
What do you mean by clearing the command log? And why do you want to clear it?
The command line is just a shortened version of the AutoCAD Text Window (F2) which stores a history of commands. As far as I know, you can't "clear" it except to close and re-open the drawing.
Okay, no worries then. Anyway, thanks a lot, both of you.
Try Ctrl+9 to hide the command line.
From your AutoCAD Help file:
"When you hide the command line, you can still enter commands. However, some commands and system variables return values at the command line, so you may want to redisplay the command line in those instances."
  • 2 weeks later...
