richardlim Posted January 5, 2011 Posted January 5, 2011 (defun s::startup () (command"-scalelistedit" "A""5:1""5:1" "A""1:200""1:200" "a""1:250""1:250" "a""1:500""1:500" "a""1:750""1:750" "a""1:1000""1:1000" "a""1:2000""1:2000" "E")) I want to create a start up lisp that when you open a new drawing is adds custom annotation scale as per the list above. It works for a new drawing. But when the scale already exist...its an error. CAn some please help me. thanks, Richard Quote
richardlim Posted January 5, 2011 Author Posted January 5, 2011 If i use a template then RESET to get rid of excess scale 1:1_XREF...... it also removes the regular custom scales which i need to use. I know is is no problem in 2011. Currently we are using 2008 and 2010. Thanks! Richard Quote
irneb Posted January 6, 2011 Posted January 6, 2011 The "best" solution I've found is to create a DWT file with only the scales you want inside. Then use the Scale List Cleanup Utility to "synchronize" multiple DWG's to match, the new one's now even got a command-line, so you can set windows's Scheduled Tasks to run it periodically. Else try my old code here: ;; Utilities to clean-up scale lists ;; By: Irné Barnard ;; Version 2 ;; Command to remove all XREF scale lists (defun c:ScaleListRemXRef (/) (princ (strcat "\n" (itoa (DelScaleListMatch "*XREF*" (GetScaleListEntities))) " XREF scales deleted." ) ;_ end of strcat ) ;_ end of princ (princ) ) ;_ end of defun ;; Command to remove all Imperial scales (defun c:ScaleListRemImperial (/) (princ (strcat "\n" (itoa (DelScaleListMatch "*=*" (GetScaleListEntities))) " Imperial scales deleted." ) ;_ end of strcat ) ;_ end of princ (princ) ) ;_ end of defun ;; Command to remove all Metric Scales (defun c:ScaleListRemMetric (/) (princ (strcat "\n" (itoa (DelScaleListMatch "*:*" (GetScaleListEntities))) " Metric scales deleted." ) ;_ end of strcat ) ;_ end of princ (princ) ) ;_ end of defun ;; Command to ensure Imperial scales are present (defun c:ScaleListImperial (/) (princ (strcat "\n" (itoa (InstallScaleList StdImplScaleList)) " scales added")) (princ) ) ;_ end of defun ;; Command to ensure ISO scales are present (defun c:ScaleListMetric (/) (princ (strcat "\n" (itoa (InstallScaleList StdISOScaleList)) " scales added")) (princ) ) ;_ end of defun ;; Command to ensure Imperial scales are present (defun c:ScaleListForceImperial (/) (princ "\nRemoving all non Imperial Scales ...") (princ (strcat "\n" (itoa (DelScaleListMatch "*" (GetScaleListEntities))) " Metric scales deleted." ) ;_ end of strcat ) ;_ end of princ (prompt "\nInstalling Standard Imperial scales ...") (c:ScaleListImperial) (princ) ) ;_ end of defun ;; Command to ensure ISO scales are present (defun c:ScaleListForceMetric (/) (princ "\nRemoving all non Metric Scales ...") (princ (strcat "\n" (itoa (DelScaleListMatch "*" (GetScaleListEntities))) " Metric scales deleted." ) ;_ end of strcat ) ;_ end of princ (prompt "\nInstalling Standard Metric scales ...") (c:ScaleListMetric) (princ) ) ;_ end of defun ;; Command to remove incorrect scales & ensure standard scales ;; in relation to the MEASUREMENT sysvar (defun c:ScaleListStandard (/) (if (= 0 (getvar "MEASUREMENT")) (c:ScaleListForceImperial) (c:ScaleListForceMetric) ) (princ) ) ;; ---------------------------------- ;; Utility functions ;; ---------------------------------- ;; List of standard Imperial scales as per AutoCAD (setq StdImplScaleList '(("1'-0\" = 1'-0\"" 12.0 . 12.0) ("6\" = 1'-0\"" 6.0 . 12.0) ("3\" = 1'-0\"" 3.0 . 12.0) ("1-1/2\" = 1'-0\"" 1.5 . 12.0) ("1\" = 1'-0\"" 1.0 . 12.0) ("3/4\" = 1'-0\"" 0.75 . 12.0) ("1/2\" = 1'-0\"" 0.5 . 12.0) ("3/8\" = 1'-0\"" 0.375 . 12.0) ("1/4\" = 1'-0\"" 0.25 . 12.0) ("3/16\" = 1'-0\"" 0.1875 . 12.0) ("1/8\" = 1'-0\"" 0.125 . 12.0) ("3/32\" = 1'-0\"" 0.09375 . 12.0) ("1/16\" = 1'-0\"" 0.0625 . 12.0) ("1/32\" = 1'-0\"" 0.03125 . 12.0) ("1/64\" = 1'-0\"" 0.015625 . 12.0) ("1/128\" = 1'-0\"" 0.0078125 . 2.0) ) ) ;_ end of setq ;; List of standard ISO scales (from ISO 13567) (setq StdISOScaleList '( ("1:1" 1.0 . 1.0) ;Scale type A ("1:2" 1.0 . 2.0) ; ("1:5" 1.0 . 5.0) ;Scale type B ("1:10" 1.0 . 10.0) ;Scale type C ("1:20" 1.0 . 20.0) ;Scale type D ("1:25" 1.0 . 25.0) ; ("1:50" 1.0 . 50.0) ;Scale type E ("1:75" 1.0 . 75.0) ; ("1:100" 1.0 . 100.0) ;Scale type F ("1:200" 1.0 . 200.0) ;Scale type G ("1:250" 1.0 . 250.0) ; ("1:500" 1.0 . 500.0) ;Scale type H ("1:750" 1.0 . 750.0) ; ("1:1000" 1.0 . 1000.0) ;Scale type I ("1:2000" 1.0 . 2000.0) ;Scale type J ("1:2500" 1.0 . 2500.0) ; ("1:5000" 1.0 . 5000.0) ;Scale type K ("1:10000" 1.0 . 10000.0) ; ) ) ;_ end of setq ;; Function to obtain list of scale entity names (defun GetScaleListEntities (/ lst item) (setq lst nil) (foreach item (dictsearch (namedobjdict) "ACAD_SCALELIST") (if (= 350 (car item)) (setq lst (cons (cdr item) lst)) ) ;_ end of if ) ;_ end of foreach lst ) ;_ end of defun ;; Function to obtain list of scale types in current drawing (defun GetScaleList (/ lst lst1 item data) (setq lst (GetScaleListEntities) lst1 nil ) ;_ end of setq (foreach item lst (setq data (entget item)) (setq lst1 (cons (vl-list* (cdr (assoc 300 data)) (cdr (assoc 140 data)) (cdr (assoc 141 data)) ) ;_ end of vl-list* lst1 ) ;_ end of cons ) ;_ end of setq ) ;_ end of foreach ;; Sort the list - most detailed to least (setq lst (vl-sort lst1 '(lambda (s1 s2) (> (/ (cadr s1) (cddr s1)) (/ (cadr s2) (cddr s2))) ) ;_ end of lambda ) ;_ end of vl-sort ) ;_ end of setq ) ;_ end of defun (setq $scalelistdel nil) ;; Function to delete scale matching a wildcard name (defun DelScaleListMatch (pattern lst / item data count) (setq count 0) (setq cmd (getvar "CMDECHO")) (setvar "CMDECHO" 0) (command "._undo" "_Begin") (command ".-SCALELISTEDIT") (foreach item lst (setq data (entget item)) (if (wcmatch (cdr (assoc 300 data)) pattern) (progn ;; (entdel item) ;Removed (command "_Delete" (cdr (assoc 300 data))) (setq count (1+ count)) ) ;_ end of progn ) ;_ end of if ) ;_ end of foreach (command "_Exit") (command "._undo" "_End") (setvar "CMDECHO" cmd) count ) ;_ end of defun ;; Function to ensure list of scale are installed (defun InstallScaleList (stdlst / lst item cmd n e) (setq lst (GetScaleList)) ;Get list of scale entity names ;; Remove items from stdlst which is already in the drawing (setq n 0) (while (< n (length stdlst)) (setq e (nth n stdlst)) (if (assoc (car e) lst) (setq stdlst (vl-remove e stdlst)) (setq n (1+ n)) ) ) (setq cmd (getvar "CMDECHO")) (setvar "CMDECHO" 0) (command "._undo" "_Begin") ;; Start scalelist edit if needed (if (> (length stdlst) 0) (command ".-scalelistedit") ) ;; Step through remainder of stdlst (foreach item stdlst (command "_Add" (car item) (strcat (rtos (cadr item)) ":" (rtos (cddr item)))) ) ;_ end of foreach ;; End scalelist edit if needed (if (> (length stdlst) 0) (command "_Exit") ) (command "._undo" "_End") (setvar "CMDECHO" cmd) (length stdlst) ) (princ) Modify the StdISOScaleList list of scales (about half-way down the code) if you want something different. The command you want is ScaleListMetric to add these scales to the DWG, or ScaleListForceMetric to also remove all scales not in the list. Quote
richardlim Posted January 6, 2011 Author Posted January 6, 2011 Irneb, that is really a wonderful program.....what can i say.....You're the guy! thank you very much!.....yahooooo! Quote
