JimB Posted January 6, 2011 Posted January 6, 2011 3D extruded model adjustment - can't achieve ... I’ve attached a 3D element I’ve spent a number of hrs trying to correct which I can’t. And I need some help from anyone that might be able to help. The attached model (in perspective view) I’ve clouded the corner that is giving me problems which is a white cloud. What I need to do is drop that corner to the same height as the opposite corner clouded in red. This is an earth ramp, I extruded the profile, then sliced it from ground level to the top of the ramp, to get as far as I have. Really appreciate any contribution, I’ve tried every thing I know to get that corner down, subtracted, what ever…. temp ramp.dwg Quote
ReMark Posted January 6, 2011 Posted January 6, 2011 If you drop that corner wouldn't you also be affecting the remainder of the edge all the way back to the first hard corner? You just don't want to taper it from the end/beginning of the curved corner do you? Quote
JimB Posted January 6, 2011 Author Posted January 6, 2011 Exactly thats the problem I'm having if I drop the corner the hole thing drops all teh way back... Which is waht I dont want, I just want to drop that sigle corner so its level with the toe of the ramp the other side (clouded red) oppersate side ... can it be done? Quote
ReMark Posted January 6, 2011 Posted January 6, 2011 Well I got it to drop but the result was not exactly what I expected. Quote
JimB Posted January 6, 2011 Author Posted January 6, 2011 Yer i know the feeling... I been getting it for last couple of hours :} Quote
ReMark Posted January 6, 2011 Posted January 6, 2011 Yer i know the feeling... I been getting it for last couple of hours :} You do realize the corner with the red cloud around it does not end in a point right? Sorry, but I've got to drop this for now. Stuff to do. I'll check back later. ReMark Quote
JimB Posted January 6, 2011 Author Posted January 6, 2011 Either plan view or side elevation I was under the opinion it did... where the red cloud is. I appreciate your time given thankyou. Quote
