Hi Folks,
We just switched to Autocad LT, lisp routines don't work.
How do you creat a leader with loop instead of arrow. We use to have a LISP command that would draw line then insert loop symbol at end of line.
Thanks in advance.
I'm not familiar with LT past about 10 years ago. You may have to draw one manually and save it as a block to insert.
--edit--
Talk to Bbankston...he has LT and could answer your question I bet.
I'm not familiar with LT other than I know that you cant use LISP. What about the dimension style? is there an acceptable loop symbol? how about creating a custom symbol and applying it to the dimension style, is that possible in LT?
Which version of LT did you switch to? Mleader might be of help as well.
