So I have a view that needs to be larger in my drawing. The view is already dimensioned and when i change the scale the dimension values changes. For example my object is 5" high when i double the scale it goes to 10", but i want the value to still say 5". I know I can individually edit each dimension but is there a quicker way?
YES THERE IS.
always draw in 1:1 scale - use paperspace and/or viewports to change the scale of views.
Your problem illustrates one of the main reasons why layouts and viewports are commonly used.
Could you solve your problem by creating a second dimension style?
model space is where you draw (1:1 always!)
paper space is where you make layouts (any scale you like)
do this - use autocad help is unsure:
create a paper space layout - based on the size paper you want to use
insert a viewport into it (command VPORTS)
set the scale of the viewport (eg. 1:2)
print from this layout
by the way - welcome to CADTutor forums!
I hope this doesnt turn in to a PS vs MS argument again.... My company does not dimension in PS(and i hate it), so we either create a new dim style as ReMark said, or select the dimensions that we want to scale and adjust accordingly in properties...
Argument? No. Debate? Maybe, but we'll save that for another day.
I want it duly noted though that the person who suggested creating a new dim style (yours truly) does dimension in paper space (layouts) and has no problems. But I'm open to everyone using what works best for their particular situation / discipline / company policy. Peace out.
Peace out.
*Drops microphone and walks off stage*
this isn't a dimstyle issue, is it? i thought it's a simple matter of dimensioning the object at one scale and viewing or printing it at another. ?
if so, the answer is simple: viewports.
I think that depends on whether the OP is working only on the modelspace tab, or if he's using layouts/viewports.
JPlanera, I'm curious why you don't just set your dimstyle to "Scale dimensions to layout" on the "Fit" tab, and let AutoCAD do the scaling?
We dont dimension in paperspace. so when doing section views at 2:1, we have to DIMSCALE=2 for those dimensions
*sigh* No... As much as I would LOVE to. we have 20+ years worth of drawings that are all in model space and trying to "teach the old dogs new tricks" proved moot for me... 2+2=5 unfortunately... for what we do, though, its not so bad
The aircraft company I worked for in 2001 drew and dimensioned on the layout tabs. the only time they did anything in model space was the rare occasion they'd allow someone to draw in 3d. I asked why not just draw it all in model and use viewports, and was told that, and I quote "that viewport nonsense just slows things down. It's bad enough to have to use a computer at all!"
