Dan4141 Posted January 7, 2011 Posted January 7, 2011 I am using Auto Cad 2011 and was wondering if there was a way to radius a part with one command. For instance if I have a square (12"x12") with 4 individual lines and I want a .25" radius on the four corners, is there a way to do that with out selecting each corner and doing a fillet radius? Quote
ccowgill Posted January 7, 2011 Posted January 7, 2011 Welcome to CADTutor, yes, if it is a rectangle, (closed polyine) you can fillet, set the radius, then select the P option (2d polyline) and select the rectangle, all 4 corners will get filleted. if it is 4 lines, you can use the boundary command to create a closed polyline rectangle Quote
Glen1980 Posted January 7, 2011 Posted January 7, 2011 Sweet! I never knew that one and it works with chamfer!! Thanks ccowgill! Quote
