johnengineer Posted September 23, 2008 Posted September 23, 2008 When inserting a block onto a layer and if that layer is later frozen, why does my block freeze as well? The block was created on a layer other than the one it was inserted on. Quote
johnengineer Posted September 23, 2008 Author Posted September 23, 2008 I guess the issue I have is that not all my blocks behave that way. Some are frozen and some aren't. It's obvious that the layer is frozen dbroada. Quote
CmdrDuh Posted September 23, 2008 Posted September 23, 2008 it could be some of your blocks are defined bylayer and others are byblock. So when you freeze the layer, the bylayer version go with. HTH Quote
