I wonder if someone can help me .............
First, I want to create a macro which will draw a polyline on a layer which will have a certain line type (hidden, center, whatever)
Something like this :
^C^C-layer;make;FC-DGNINFO_F_C_CW-412;color;blue;;;pline \w;0;;
I tried several option such as
^C^C-layer;make;FC-DGNINFO_F_C_CW-412;linetype;center;color;blue;;;pline \w;0;;
But it didn`t work out.
Second, another macro which will calculate length of existing polyline and place the value on top of the line.
I am using AutoCAD 2010 version
Thank you!
Edited by SLW210
There are a couple of lisp routines, here at CT, that with display the value of a picked line and place it above the top of the line. A quick search should turn one or both of them up.
I`ve been searching the forum and haven`t found anything that work with 2010 version. For the first macro, second option is what I found in the forum but as I mentioned, it does not work with AC2010.
I am assuming it takes some minor tweaking in the code ........ tried several options but couldn`t figure it out.
I managed first macro to work, just a little tweak........ but I have another problem, can not save macro , when I close AutoCAD and open it again, non of macros are working ....... that`s so weird ........ anybody has idea?
Assign the macro to a button. You'll have to edit your CUI.
Another option might be to use the Action Recorder found on the manage tab of the Ribbon. See the Action Recorder panel.
I did that............ for some strange reason macro is not saved.
I had similar problem with 2008 version , macro box in CUI was grayed out so I couldn`t edit it but in this case I can edit it but not save it ..........
The process for creating a button and assigning a macro to it is pretty straight forward and usually presents no problem whatsoever. Perhaps you missed a step. Are you following the steps laid out in your Customization Guide?
  • 9 months later...
^c^c-la;m;LAYERNAME;lt;hidden;;c;1;;^c^cpl;
Edited by SLW210
Added Code Tags
