Hi every one,
it's my first time to use the lisp program. my problem is when i find a lisp file where should i save it.
thanks u:)
Bookmarked for addition to the FAQ part of the site :thumbsup:
Sorry, I can't answer your question, but somebody will be along soon who knows :) (or you can search some old threads as I'm pretty certain it's been asked before)
I sometimes save to My Documents or into our network, if the other guys want to use them.
I usually save mine under the support file in autodesk and add it to my start-up suite so that it is loaded everytime i start cad
if you save them in a pathed folder you can then load them with (load"myLisp")
Over time, you may find you have collected quite a few lisp files, blocks, and script files, etc.
I would create a folder named after each file type and keep these folders in your support path.
Here's my setup:
c:\MySupport\blocks
c:\MySupport\drawings
c:\MySupport\routines
c:\MySupport\scripts
I have mine all in a "lisp" folder and just call them when I need them via appload.
